Right – I have some good news!
I was referred to a private physio by my work as it was impacting on work. Thankfully we have a different provider now so I got some excellent care.
After a long first session of tests the physio found that as I had a weak right leg. Basically I damaged both Achilles – the left one got better quickly but the right didn’t. As a result he thinks I’d been favouring that leg for so long to reduce the pain it had been underused and become weaker. I could definitely tell very easily that I couldn’t do the exercises he was giving me on my right leg even half as well as my left.
He gave me exercises to strengthen the leg and to also re-learn my tolerance to pain in the affected area. He said that Achilles exercises alone wouldn’t work which was very true!
So after 4 sessions and putting in a lot of work myself I’m pretty much sorted and have ridden quite a bit on holiday and hoping to start running again.
I think this is a warning to people who try to self-diagnose. I would never have found out myself that this was the issue, and could have done long term damage if I went down the wrong path. I’ve had a similar experience with a damaged neck too.
I would say if you are treating the issue as soon as it happens the internet research and exercises based on that might be much better than waiting weeks for an NHS physio and worth a try before you pay for one. However if you’ve had the issue for months or years you need to see a good physio who will treat the problem at its source and correct all the issues which exacerbate the problem.
Unfortunately not all physios are good. Out of the 7 I have seen over the years only 2 treated the root cause of the issue to eliminate the problem, the other 5 treated the symptoms so the issue was relieved for a while then came back (I have a 10 year long story about my neck which I won’t bore you with!).
The best physio I went to I would gladly pay the £50 a session fee myself for the wonders they did with me.
