I just wondered what should happen if you fitted a SLX Hollowtech BB and chainset on a 68mm BB shell frame with one spacer on each side, instead of 2 on the driveside and one on the non-driveside?
I’m going to be fitting a BB mounted Blackspire Stinger to my Fury but I noticed that the LBS only put one spacer on each side instead of 2 on the driveside and 1 on the non-driveside. What problems will I encounter when I try to fit the Stinger instead of the only driveside spacer?
It’s been run with one spacer either side for at least a couple of hundred miles so far. It’s running smooth. Should I have noticed anything, or are there problems to come?
