Copied and pasted from the last dashcam thread because I can’t be arsed typing it all again…
Whatever the cheapest Nextbase one is at Halfords.
Not because they’re the best cameras or anything but because the hardwire kit is easily available and a doddle to fit.
The camera will become a pain in the tits to use if there are trailing wires or you need to manually switch it on and off all the time.
I only need to remember to format the card every couple of weeks, otherwise it’s fit and forget.
Also, get one that records in higher FPS rather then HD
The resolution won’t do you much good if the car you want to identify has shot through your range of vision at 80mph when you’re recording at 24 frames per second. The number plate’ll be a blur.
At 60fps you’ll have a fighting chance.
