New MTB frameset on the way. I have a pile of bits, but those bits—along with my knowledge of MTB bits—dates from 10-25 years ago. Basically I kept up to the point of 9 speed, when pretty much everything worked with everything else, and then swapped to road riding instead.
I can build this thing singlespeed, 1x, 2x or 3x. Probably singlespeed first to try to reclaim the good old days, and then if my dodgy back can’t cope with that then I’ll have to go 1x or 2x unless I find a cheap Alfine hub 🙂
I have a pair of M511 shifters, some singlespeed rings, and a new 9sp chain and 11-32 cassette kicking about, and I want to buy as little new stuff as possible.
Main thing here is whether Shimano have been fiddling with cable pull ratios since I last bought anything.
So, the 1x (yes, I know an 11-32 isn’t an ideal 1x cassette) questions:
– I guess a Shadow mech is required; will any/all of those work with my M511 shifters?
– With a clutch I’m guessing a narrow-wide ring is still necessary? Or can I wing it with a singlespeed (ie unramped) ring?
And the 2x questions:
– The full build of the same frameset comes with an M617 front mech, which has a front pull via the down tube and is designed for a “proper” double (rather than what I’ll be using, which will something like a 22-32-bash on an old triple). Will it play ball with the 22-32 on a presumably narrower chainline and, again, will it work with my M511 shifters? (The frame has routing for a top-pull as well, so I can always fall back to an old triple.)
Muchos gracias
