I’m a big fan of drilled lugs, they make for a really easy strap swap with just a small pin tool and without any risk of scratching the case. I can see why they might be undesirable on something super dressy and refined but I just can’t see an argument against them on any tool-type watch and don’t know why they’re not more common.
Prior to buying my Seiko SPORK, drilled lugs are something I’d never come across before, and my first thought was, why the hell isn’t that used more often!
The SKX007 that I’m getting and modding will have the lugs drilled like the SPORK, with oversized 2.5mm spring bars. Being able to just push the end of the spring bar in with a bit of wire, instead of having to faff around with a specialist tool, especially with tight-fitting rubber straps just makes so much more sense.
