Possibly one for that thread about mechanical mishaps but anyway…
2013 2.2 diesel Transit, 100k-ish miles.
The low oil warning light came on as I was going to work.
After work I checked the oil, yep, wee bit low, right at the bottom of the dipstick so I topped it up.
Drove 5 miles to a petrol station.
There was a funny burning smell when I stopped, must be that fire in the yard over there.
Filled up, and set off again. The low oil warning light was on again. I wonder how long they take to register that it’s got more in now? Maybe it’s still not enough, I’ll leave it to settle and check before I use it again.
I got home, andother 9 miles, so 14 miles altogether. There was still a burning smell, albeit much stronger. Smells like buring rubber. Is it me?
I opened the bonnet.
Bollox.
I hadn’t put the oil cap back on. Oil everywhere.
It had been running fine so I don’t think I’ve buggered the engine itself. I can get some more oil and refill easily enough, not sure how much I’ve lost but it really is everywhere so probably a good time to change the filter and things rather than just top up.
The question really is, how much damage has spraying oil all over the alternator, some of the belts, the electrical connections, etc, etc likely to have done?
Should I get it professionally cleaned sharpish or just leave it to drip and then let heat do the rest as I drive about? Anything I should do immediately to prevent further damage, is there anything which should be cleaned NOW?
Thanks
