Home Forums Bike Forum How do I know what type of forks will fit my frame.
Viewing 12 posts - 1 through 12 (of 12 total)
  • How do I know what type of forks will fit my frame.
  • johnj2000
    Hi, I have a 2005 GT Avalanche 1.0 sitting in the garage in disrepair. I have decided to strip it back to the frame and upgrade the parts. 2 initial questions but as with the Cotic build earlier this year I am sure I will have plenty more.
    1. I have heard that some frames don’t take certain fork types. How do avoid an expensive mistake in ths area?
    2. Hose length for hydraulic brakes, how do you determine the length required? I am buying 2nd hand so need to know what will work.
    Cheers.
    J
    Teetosugars
    If its a 2005 chances are the forks will be standard 1/18 size, ie not tapered, or 1.5″..
    As for hose length, chances are if you’re buying 2nd hand, they will be long enough as the previous owner won’t have cut them too short.
    johnj2000
    Is there any way of telling whether it’s standard or tapered?
    couldashouldawoulda
    According to CaneCreek its a standard headtube – headset:
    SHIS:ZS44/28.6|ZS44/30 (1-1/8″ Zero Stack ZS Standard)
    http://www.canecreek.com/headset-fit-finder
    Bazz
    It won’t be tapered, but if it was the bottom of the headtube would be wider than the top. pretty sure that frame is only going to be rated for 100mm travel forks as well.
    donsimon
    You’ll be able to tell by looking at the steerer or asking the seller.
    I think the fork length will be an issue to, the frame will have been designed to take certain fork lengths.
    What fork is coming off?
    passtherizla
    google is your friend…
    100mm rockshox….
    johnj2000
    The fork coming off is a really pants suntour thing which is about as much use as a chocolate fire guard. Was thinking a max of 120.
    johnj2000
    It was a Halfords purchase so the parts are different than those stated ont interweb. 100mm it is then.
    passtherizla
    I didn’t know Halfrauds do that!? outrageous!
    johnj2000
    I know, it’s a shocker 😉
    donsimon
    Should be OK with a 120mm s long as crown to axle is increased too much.
The topic ‘How do I know what type of forks will fit my frame.’ is closed to new replies.
