Hi,
So, for some reason the tap in our kitchen no longer gives us hot water. Every other tap in the house now does (after boiler repairs).
If I take off the end of the tap, the boiler still does not kick in, so I know it is not the end of the tap reducing the flow rate and causing it.
If I disconnect the tap and run straight from the connection into a bucket, then it does appear to give us hot water – the boiler engineer did this, I have not verified myself again.
I can’t see anywhere else within the tap except the lever where there could be a constriction. The tap is less than 2 years old and we have what I would call slightly hard water. South Downs level of hardness rather than Thames Valley level of hardness.
The flexible hose under the sink is as tight as it will go in a bend, could this be causing a reduction in flow which is not noticeable, but enough for the boiler?
Is it in reality likely to still be a fault with the boiler rather than the tap? (Worcester Condensing boiler about 10 – 13 years old)
Anyone have any other ideas I could look at, not there there is much left as far as I can tell!?
Greatly appreciated.
