I have some (non flatmount) RX4 paired with road 4700 hydraulic sti levers, on a frame that is being retired.
Basically will these work with the hope Tech 3 V4 Levers?
Since the brakes seem to be the same thing, they use the same pistons (14mm and 16mm) and parts, so i’d assume the brakes are set to push the same amount of fluid into the calipers?
I’m trying to do a bit of swapping because I have some flatmount grx calipers that will fit well with the 4700 sti’s on a new frame. Which leaves me with the rx4 calipers, but i’d like to put them on a mountain bike since it has regular old school mounts.
Is this mad?
