Last time I calculated a DT350 15×110 while the spoke lengths were different to the 15×100 as expected, by the time you took rounding and available lengths into account, the same spokes would be called for in practice. I’d also encourage you to do this exercise partly for your own peace of mind but also because as above, you might get a surprise.
I’ve used the single sided Hope front Boost adapter and if you aren’t overly OCD it works fine with a minor redish (probably only about one turn per spoke but use a dish stick). It sticks in as well as a normal Hope adapter but obviously as you’re redishing, if you put a 15×100 back in to shift it to another bike you’re going to be off centre unless you redish again so it’s a less on-the-fly solution than many are used to. Rear wheels present more of a problem as you absolutely need to move the disc too but this isn’t insurmountable.
Generally, I’d consider adapters if there was a very good reason I didn’t want to strip the wheel (in my case, a nice JRA custom build) but otherwise especially if putting a new bike together I’d seriously consider buying proper Boost hubs and shifting the old hubs while non Boost is still attractive to people…
