I’ve just purchased a second hand hope pro2 evo wheel and when fitting the rear wheel to my frame it seized once i’d tightened the qr.
I have taken the wheel out and check all is spinning freely and it all seems fine.
Though upon inspection it seems as though there is a slight grounding out of the bottom section of the silver drive side qr adapter. I think that somehow the surface has been worn down to the point that the adapter is now pushing against the bearing rather than the inner race.
looking on the hope website and hub diagram it does not show any extra washer / spacer to stop the adapter from touching the bearing, but as this is my first Hope hub I am not sure if I am missing something or whether it is the minimal wear on the adapter that’s causing the problem.
can anyone provide assistance as to whether I need to replace the adapter or fit a spacer etc?
thanks
4130
