@spooky_b329
yep, I’m sure it’s all level. Bike looks straight. The wheel does sit off centre on the roller, but there’s nothing I can do about that as one side (the non drive side) of the wheel clamp is fixed, so the offset from there is the only place my wheel can end up laterally. It could be frame flex, but once it settles in, it just stays there i.e. I sometimes put the bike on the turbo and spin the wheel and it looks fine, but once I pedal properly it slips laterally, then once it’s gone it doesn’t flex anymore, just stays wonky.
@pdw
Vertical dropouts. It’s just my normal road frame.
Bearing play – not obviously. Wheel seems fine off the bike and on the workstand. But unless it’s the rear triangle I guess the movement in these circumstances is telling me that there must be.
The turbo does stress it in a way I can’t manually. Maybe it was an obvious question but I needed someone to ask it. I hate faffing with bearings. I’ll have a proper look now.
Thanks both.
