Due to digging and landscaping I need to put up fence posts in a bit of ground that is currently about 200mm below where it. It will be backfilled to the level where it will form part of a walkway, with gravel on top – so nothing’s going to be grown in it (hopefully, at least). I want to put fence posts in this bit using post holders, and the ones I have are about 200mm deep. So if I backfilled the ground then dug another hole to put the fence posts in then most of it will be in the backfilled soil and I’m worried it won’t be solid enough.
My options are:
1. Get one of those longer pointy post holders, whack that into the ground and concrete around the base of it
2. Plonk the post holders I have on the current ground level, concrete around it and whack dirt around it whilst it’s still damp.
3. Something else
What would STW do? The ground I have is clay with shitloads of stones in it.
