No probs
FWIW I'm running the model before the one ebuyer are selling now… Which was £219 when I bought it.
Specs almost identical except mine is a 2.6GHz Pentium Dual Core and not a 2.8…
Anyway, as PC's go (I love Mac's I'm afraid to say!) it's brilliant! It overclocks by 20% instantly (should you be into such things) through this nifty bit of software or through the BIOS if you know what you're doing.
I did a few benchmark tests on it a few months ago and it chucked out some results that wouldn't be shameful on a machine costing more than twice as much (base unit only again).
Only thing I will say is the standard CPU and case fans are a little noisy, but then they're set to 100% in the BIOS as a default. The Pentium Dual Core processor does not run very hot at all, even under full load, so you can afford to mess about with the fan settings in the BIOS (I've got mine set to very low, until the processor is under load when they speed up a bit) to quieten everything down though.
Put it this way, for a budget machine I'm amazed just how good it is and what you can do on it! I really should get a 64 bit OS just so I can utilise all 4GB of RAM to be fair…
Oh, should add don't know if the standard GFX are up to much cop as I put an NVIDIA 9500GT 1GB GFX card in mine from new, which was a bargain at only £40. Works nicely with my 23" HD Samsung screen with no delays for anything except gaming!
