See that bridge up ahead? See that big motorway style flashing sign that’s triggered by a beam half a mile back down the road? If you can zoom in you can probably see the mountain of discarded fiberglass from lorries hitting it pretty frequently.
Turns out that however big and flashing the sign is, people just don’t pay any attention to them!
That bridge must be built out of damn strong stuff.
I built a “jig” – clamps were too short… so I improvised. Wasn’t great but it worked.
silkaflexed it to some thick ply
resined the crack
It’s definitely strong. The finish isn’t great, so I might put some more resin in and maybe try and touch up the crack another way. You can’t see the ply unless you look underneath. I might grind out the crack and make it a “feature”, but I probably won’t. The cat will probably break it again before then.
I also drilled out the legs and replaced the threaded inserts with bolts right through.
8 metal brackets to hold that wooden bit seems overkill when the weight of the actual table top is supported by the frame sides of the table structure.
Why does it need to be fixed and why the time constraint. I have only just seen this thread so might not be able to help in time but thought I would check.
I watched the Repair Shop last night on BBC (wonderful program, great craft and lovely stories) and one piece was rebuilding a smashed alabaster lampshade from about 40 bits back into the whole.
I know it’s too late for you but they didn’t use a large piece of ply, araldite, or a kettlebell, and they made a way better job of it than you 😉
I like the idea of highlighting the repair rather than hiding it. A stylish crack that you like looking at sounds way better than a horrible old one you try to hide away.
