I think you are up on environment aspects, but for EA check their web, https://www.gov.uk/guidance/flood-risk-activities-environmental-permits
Best get EA right if you sell at any point in the future, unless going full DIY.
My be worth professional input with water source from a river, often use lakes as there is a body of water taking solar input, sun!
Also note that quoted figures for output from heat pumps use a standard temperature, where in real life temperature varies, ground source is more stable. Mentioned before somewhere, you don’t get much heat from 0 Deg C in winter and end up using electric heating.
The other aspect from a flowing river, if suitable, is hydro, again different options and scale may not work unless low electric user. But you may combine a few ideas with stove/bio-mass/log burners/PV, just see how costs add up.
Photos of the project would be good 😉
