I’ll try to check the new fork settings today. I’ll also try to run the rebound a little faster, I suspect the form is not recovering fast enough from strikes and keep reading as the pros run rebound quite fast (grain of salt here).
If this doesn’t work, then I might try the reverse, going back to 2 tokens and up pressure to mid 80s. This based on the theory I read sometimes that firmer pressure can keep the fork in the softer travel section and actually make it feel plusher.
If nothing of this works, then a damper upgrade might be on the table. 200 euros, outch…..
Those new Radon Swoops 29 look sweet. The right travel, crazy value and the short seat tubes allow to select size based on reach (would go XL straight away). Quite tempting to get the cheapest model, 2500€ and swap the better bits I have on mine.
But:
– on the slackest setting the BB is crazy low
– no metric shock…
– hard to find any info or feedback on them
Edit: about the possible new Strive, knowing Canyon it’s likely to have quite conservative geo
