I want to hang a couple of hard tail 29er MTBs on a wall, and wondering if someone has tried someone similar to this. I have a couple scaffold style poles I’d install perpendicular to the wall at the same height (weight shouldn’t be an issue). Then the plan would be to hang the bikes by lifting / sliding the bikes onto poles through the spokes of the wheels having the bikes weight then resting on the top of both wheel rims (pipe lagging to protect the rims). I can’t be 100% sure if the bikes would be stable stored like this, and not likely to topple or lean. I’m wondering if anyone’s done anything similar before I butcher the wall, even better if you have pics 🙂
I realise that I could just hang them from the top tubes, but it’s a small space and because I’d put them bars to saddle, saddle to bars and the top tubes are super slopey, it’s not going to work, for the same reason I don’t have the room to hang them vertically.
Thanks in advance 🙂
