Viewing 40 posts - 1 through 40 (of 129 total)
  • Hambini – MTB frame.
  • Premier Icon rumbledethumps
    No punches spared on this particular outing.
    Premier Icon Onzadog
    I love the fact that he calls out bad QC/QA, but it’s clear he’s not familiar with mountain bike bottom brackets.
    Premier Icon weeksy
    I wouldn’t pull my punches on him that’s for sure.
    Premier Icon dangeourbrain
    Please tell me he moans about the iscg tabs clamping points not having been removed after it was machined.
    Premier Icon kelvin
    One of many reasons to have the plate with ISCG mounts recessed from the BB face, and then use spacers on the bolts for the chainguide/bashplate whatever…
    SodaMAX
    Hold on… might not be clear on that Ti frame… here’s a painted steel one that should make it easier to see…
    SolarisMAX
    I’ve little desire to watch the potty mouthed one but I’m intrigued kelvin what’s benefit sitting the plate behind the bb surface that the spacer behind the DS cup doesn’t serve?
    Premier Icon kelvin
    The video shows you why quite early on (but only after lots of pointless swearing, of course).
    Premier Icon kelvin
    Basically, you need to be able to face BB shells, which you can’t easily do when the ISCG mount plate is trying to be flush with the end of the BB shell. Made even worse with Titanium.
    Ah, fair do, that makes sense.
    Premier Icon Akers
    He comes across as very unprofessional, which tends to undermine his assessment, regardless of whether they are correct or not.
    All that hyperbole is ridiculous. It doesn’t help that he appears to base his assessments on very small sample sets, in this case 1, when roasting a product or manufacturer.
    Premier Icon wobbliscott
    Engineering is Engineering and is product agnostic. Irrelevant if it’s a road bike, mountain bike or not a bike at all.
    He had the same issue with the Open Up frame. It had a dropped drive side chain stay to create tyre clearance but resulted in a really strange shaped and contoured chaninstay around the BB area. Hambini had no idea why it was designed like that but highlighted that in that area there were loads of voids and defects in the carbon lay up due to the extreme shape in that area pushing the limits of the carbon lay up process. Just plain and simple poor design.
    He’s an acquired taste and who knows if he’s just picking up on the odd Friday afternoon / Monday morning frame, but he’s certainly showing up alot of the big premium bike brands for a bunch of amateur chumps. Just goes to show just because you’re paying a premium for a premium brand you’re not getting premium engineering, design or manufacturing quality.
    Luesher Teknic is good for similar insight if you like things a bit less sweary.
    Premier Icon kelvin
    Agreed, I can only watch a few minutes without wanting to switch him off… only watched a few minutes of this one, because I saw the Kingdom, and they tend to be well thought out and built, so was intrigued…
    Premier Icon Nobeerinthefridge
    He’s a tosser.
    Premier Icon teethgrinder
    Did he…did he say that whoever fabricated the BB needed a dose of Cyclon/Zyklon? @22 mins
    Premier Icon tomhoward
    Wouldn’t be the first time. He thinks (or, says) anyone who worked on GXP should kill themselves, and told his audience as such…
    Not watching the vid/giving him the click. What he sees as catastrophic failures are, in the vast majority of cases, good enough for the intended use within a budget.
    Premier Icon steel4real
    I’d say well done Cotic BUT the standard actually shows the mount is 2.5mm inboard from the BB face ISCG 05 and also describes it “Variable tab setback amount – preferred to be in 2.5mm increments”
    Premier Icon thisisnotaspoon
    Except is it really that big a deal?
    When external BB’s first appeared we all ran down to our LBS to pay £20 to get the BB faced as the internet and MBUK told us we had to. I think I had my first frame faced, then after that never bothered, and never noticed any difference in BB longevity. Winter kills them with grit and water through the seals in a few hundred hours, not the minutiae of alignment tolerances that make the difference to a bearing in your car’s engine that’s expected to last 10,000 hours.
    Premier Icon 13thfloormonk
    Nope, he’s just applying un-necessarily high standards in most instances.
    …exactly.
    If every brand starts making ‘Hambini-approved’ products with NASA standard engineering and QA, do you think the manufacturers will just suck up the hit to their profit margin? Nope, we’ll just pay more for it.
    Of course, you could argue that we’re already paying too much for most products but I choose to believe that no-one is getting rich in the industry…
    Premier Icon alexnharvey
    That man needs an editor.
    Premier Icon benpinnick
    If your frame comes and its not faced or at least bare (in the case of carbon you should have a clean shell free from resin blobs etc.) then you should just send it back. Plain and simple. If you need to face it again during the time you own it then you need to question your BB choices…
    Bike manufacturing (at least for above BSO level) has moved well beyond the days of when everything needed re-finishing when you get it.
    Premier Icon stevextc
    Well I’m all for torturing them 1st …
    Obviously excepting GXP
    Premier Icon kelvin
    I’m not saying that we, as riders, need to face BB shells, or that we should be having to get the LBS to do so… just that it has to be possible to do so… by whoever preps the frame initially.
    Premier Icon kelvin
    I’m still using GXP BBs, with no bad stories to tell.
    Premier Icon sillysilly
    To be fair most of the stuff he gets upset about is sold & priced as high end. We’re talking a £1300 ti ht frame here. If it was a £99 on-one frame then fair enough.
    He’s got quite a unique style but you must have to be a bit random to want to get on YT and make long videos about bike frames that are clearly not profit making. Especially when opening yourself up for legals. I find a lot of value within the randomness. He’d be great to have at the table for a post ride beer 😂
    So are (tens of?) thousands of others globally.
    Exactly. he’s applying the standards of multimillion pound aero products. To a bicycle frame. yes its expensive for a bike frame, but within his scope, its nothing
    Like when a 3 michelin star chef labels your local gastropubs food as ‘inedible’ and that chef should kill himself for not chopping the carrots to an exact size.
    For about 3 seconds until he got you all given a right kicking for being a gobby wee shite.
    Bullshit. They weren’t good enough for the intended use which is why their owners sent them to him to investigate and fix, presumably at some cost.
    Premier Icon Richie_B
    The only problem with that is most of the brands he highlights aren’t budget brands or products. As far as I can see he is only holding them to the tolerances the frame manufacturers (or in the case of bottom brackets the component manufacturers) state which shouldn’t be too high a target.
    Its a shame the swearing & misogamy are a huge barrier to issues we should be complaining about
    Bike frame at £1k+ shouldn’t be shredding bottom brackets or have issues when pedalling. £3k carbon road frames shouldn’t have voids and bb issues.
    Wouldn’t quite call it aerospace grade.
    In the vast majority of cases
    No, but they aren’t money no object either, there’s a limit to what they can do within what they have to spend/can sell for
    So you’d spend 1300 quid on a frame and console yourself with the hope that everyone else’s is working fine and suck it up when they tell you it is within tolerance? Don’t think so.
    That what Quality Control is for.
    No people sent them because he’s a sweary bully and they like watching him be a sweary bully on YouTube. They’re the same people who liked to watch the class geek get beaten up at school.
    If they wanted it fixed they’d have had much cheaper and greater success with the manufacturers or someone local who didn’t run a you tube channel that makes trump look coherent and restrained.
    Premier Icon dovebiker
    Regardless of how he says it, making / selling frames when the BB shell isn’t square is making rubbish. Machining and cutting the thread on a BB shell is a simple lathe job and there’s no excuse – it’s not just QA/QC it’s just crap manufacturing – no matter how many times you look at it doesn’t go away – it’s still a pile of poo. First off, the frame manufacturer made a pile of rubbish BB shells and even worse made from with them. The fact that Kingdom let it go out the door in that condition just compounds the problem.
    Yep. And it’s expensive. How much more would that frame cost if they guarantee’d every one would be perfect, to minute tolerances. Would they be able to sell it?
    Sucks if you are the one that falls though the cracks, but proclaiming the whole production run is dogshit because an angry little man on the internet found the bad one is a bit silly
    I’ve got a freeby steel pen in front of me right now. Might have cost some company a couple of quid at most yet the round bits are actually round and fit together.
    You realise that is exactly what QC is for? If tolerances were +-100mm +99mm is in tolerance, it might not work but its in tolerance so it’s a QC pass.
    Or are you saying that the tolerances are wrong? which is not what QC is for.
    Premier Icon kingmod
    The issue on this frame is exacerbated by the use of a Cane Creek chainset and the bearings. I’m guessing a normal shimano bottom bracket wouldn’t be so adversely affected. Having said that the design of the ISCG mounts on this frame is poor. Acceptable if the frame cost a couple of hundred pounds, but not on a premium titanium frame.
    They just need to do it to the tolerances of the BB’s they fit.
    It doesn’t need to cost more, they have a manufacturing/design problem preventing them getting even close to the required tolerances.
    Don’t be dense. It’s the same as case tracking versus population sampling for covid. Both tell you different things and it would be very difficult for an individual to attempt population sampling of bike frame quality, although it would be awesome if someorganisation did it.
    It is perfectly valid to take the shit ones that are sold to the general public, show how shit they are and make inferences from that.
    In several cases the buyers sought help at length from the retailer and manufacturer and not got a resolution or been told that they met the manufacturer’s tolerances.
    I don’t expect a frame to be aerospace quality, just to be manufactured to a reasonable standard.
    I expect the bad ones that don’t meet that standard to be identified by QC.
    I expect the bad ones that someone poor punter like me buys to be repaired or replaced through good customer service.
    I am glad that when that process doesn’t work properly someone points it out.
    Premier Icon argee
    Not watched the video, but guessing the whole argument is against alignment and lack of proper facing, it’s not difficult to do properly, not even with titanium, if you’re making dozens or hundreds of frames, then there should be a simple tool provided to do a quick check, doesn’t even have to be threaded, but if it is it would double up on checking the threads.
    Again, you don’t need expensive machines to skim or face, you can do it by hand with simple stones/papers/etc.
