Cheers dave I will defo take you up on the loan for a couple of rides if that’s ok. Same as you stem wise 40/50mm stem as an average so it should be ok.
The other thing I’ve sort of noticed or been thinking, is the longer reach bikes I’ve got! 495/510 mm respective! both with 50mm stems so at best I could knock 15mm of that with a stem
it seems due to that that I just can’t load up the forks due to the issues and I’m only using about 50/60% of the forks travel so that’s starts to fatigue them quit a bit after an hours riding. Even down here in shandy drinking central southdowns terrains 😜.
Taken a bit of a risk and sourced a frame reasonably cheep with 470mm reach which is what I was riding reach wise 2 years ago and felt fine on. So guess I’ll see tomorrow how that works out.
