OP, have you now managed to bleed your Guides? and yes, I do wind the reach adjsuter out to 80cm before bleeding. If you havent managed this, my bleed kit came with some really good written instructions, I could scan these and send over if this would help you?
Mboy, Ive never bled the Guides from the bottom up, I noticed when watching some of the above videos, pre bleeding edge adapter you bled bottom up, then since the bleeding edge adapter it was top down. Is there a reason you do it reverse? or is it just what works for you?
I do have a question myself for the hive mind, I bled my guides on the weekend, rear bleed fine, however when bleeding the front and pushing the plunger down to pressurize the system, fluid was escaping from what looks to be a blow off hole on the back (edge closest to the bars) of the lever, anyone else have this? I assume it was a fall safe system for when the pressure is too high when bleeding? The brake works fine post bleed, just surprised me at first as I thought the lever had given up the ghost.
