The sealant isn’t there for the installation it’s for sorting out small (and not so small) punctures when you are riding. Do the setup right and you don’t need sealant for the tyre to stay seated and inflated, admittedly I don’t get all my installations perfect so I’ll use the sealant as a post install fix. Most current rims seem to work fine, even those not explicitly marked as tubeless ready.
Yep, although popping one bead off the rim shouldn’t change anything, the only reason for doing a dry run without sealant is really just to prove its going to work and not be a waste of sealent.
If it goes up once without sealent it’ll go up again.
Inflate the tyre to the maximum pressure marked on the casing and everything should pop, and fix, in place.
With a few caveats,
1) non tubeless tyres frequently dont survive to anywhere near their max pressures (55-60psi for a lot of mtb tyres). I’ve blown two off the rim today at a smidgen over half the pressure printed on them, and had others blow off in the past. Even had one bead snap entirely in the past.
2) rims often aren’t rated to 60psi.
3) some rim/tyre combinations are explicitly prohibited. Stans IIRC have at various times said never to use schwalbe and WTB tyres on their rims for various reasons like the bead being the wrong shape, or too tight (to the point of failure).
Anyone used Stans Race Sealant and poured it in through the valve with core out, or is it too thick ?
No, but I use OKO which has the consistency of yogurt, ive never tried but just assumed it wouldn’t work.
