GoPro mount on fork lowers
Viewing 7 posts - 1 through 7 (of 7 total)
  • GoPro mount on fork lowers
  • Premier Icon sirromj
    Subscriber
    I have one of those cheap bag of assorted mounts but none seem suitable around the lowers of my RokShox Yari fork. The ones that wrap around things really need a larger circumference.
    What have you used to mount camera to fork lowers?
    Premier Icon spev
    Subscriber
    I’d not recommend it, last time I tried I used a GoPro roll bar mount, no matter how tight I did it up, it rotated, inner tubes under the clamp, bits of rubber, gaffer tape, nothing stopped it moving. To the point where it went in my wheel and got flung about 50 yards down the trail in front of me.
    Maybe you could rig something up from the disc brake mounts? at least it wont be able to rotate then
    legend
    Member
    As it’s an unsprung part of the bike, wouldn’t it be a pretty rubbish place to mount it anyway?
    Premier Icon scaredypants
    Subscriber
    surely fork lowers are too bouncy to make decent footage ?
    Premier Icon spev
    Subscriber
    there’s that as well, the footage of the camera flying down the trail was funny though, under the down tube is quite good, facing through the fork, but I find most POV footage either makes me sick after a while or it makes everything look flat.
    Its good if its used sparingly with static and panning footage though
    CraigW
    Member
    Maybe some way of attaching it to the axle? If you have QRs, you could replace the nut with a mount.
    eg KCNC light mount. https://clee-cycles.co.uk/P3104/product
    Or Nut-r http://www.nut-r.co.uk/products1/index
    Subscriber
    Ok, thought it worth a try. Will probably try bodging something with P-clips and a stiff rod, as wanted to get camera below axle (but not too far) without adding any additional movement.
The topic ‘GoPro mount on fork lowers’ is closed to new replies.
