Ok do you want to choose “pre level 1” then have can and next auto complete?
If so…
For good practice – Get rid of the blank rows, don’t have them in working data except to break unrelated ranges, they’re fine on your output sheet but in working info use lines and borders to provide a visual break if needed.
Then format your control, it will have a linked cell option. Set this to a free cell on your working sheet (sheet2!z1).
Check the output in “z1” it will be either the chosen text or a number (position in sequence)
If its text then your “can” cell wants to contain =vlookup(sheet2!b$4:d$60,sheet2!z1,2,false) where 60 is your bottom cell in the table of can/next.
“Next” cells as above but change the column number from 2 to 3
If the output is numerical then “can” becomes
=index(b$4:b60, sheet2!z1)
Next
Same but change the column from b to d[/s]
Ignore that it won’t work. I’ll send something across later
