So had a go at it last night. Rons on AC Race Wheels.
Did as advised, tube first, then took it off, re-inflated without the tube. Couldnt get it to seal so poured loads of neat Fairy liquid round the bead. I see the point of that now, there wasnt any problem at all getting the tyre on to the rim, the soap provides just enough temporary seal to keep the air in and get the tyre back up.
Valve core out then poured in 2 cups of sealant through the valve via the little white bottle. Pumped back up, swirl the tyre around and that seemed to be that. Were a couple of obvious leaked in the sidewall but the sealant managed to fill them eventually.
Came down this morning, one tyre still fat, the other had gone down. Found another pin-prick size hole with sealant dripping through. Pressed my finger on it, that seemed to get it to seal, will see how it is this evening.
Is this the normal state of affairs with tubeless? Do TR tyres naturally have a few holes in them when you get them that you have to be patient with? Am I going to find the tyres flat a few days after a ride where I have to get the sealant working again?
Thanks
