- This topic has 25 replies, 13 voices, and was last updated 2 years ago by julians.
Gas meter fault?
juliansFree Member
So over the last few days (since saturday) I’ve noticed a substantial increase in the amount of gas being used displayed on our smart meter remote display (I mean actual kwh of gas ) , it shows hour by hour usage , and there is a substantial amount of gas being used at hours of the day when no gas appliances are running, as well as much higher than normal usage when gas appliances are running.
So today I shut the mains gas valve off – this is the main valve before the gas enters the meter, and took a photo of the meter reading on the gas meter itself – it read 32528.836 cubic metres .
71 minutes later I took another photo of the meter reading, it read 32530.375 cubic meters. Which works out to 1.539 cubic meters of gas used, despite the main valve being closed.
This pretty clearly points to a fault with the gas meter doesnt it? ie its counting gas when the main valve is closed
Just checking I havent missed anything before I get on to shell energy.
TIA
juliansFree MemberJust checked again (132 minutes after turning the mains gas valve off), and the meter is now reading 32531.871 cubic meters.
so the meter thinks we have used 3.035 cubic meters in 132 minutes with the mains gas valve turned off.
anyone know how gen 1 smart meters measure the volume of gas used? This would seem to be an odd failure
airventFree MemberSmart gas meters are a lot less ‘real time’ than the electric meters. Turn it off for about 4 hours and see what it records.
juliansFree MemberSmart gas meters are a lot less ‘real time’ than the electric meters. Turn it off for about 4 hours and see what it records.
Thanks – I was aware of the lag on the remote display, so I’m not using the remote display to determine gas used – I’m looking at the display directly on the gas meter itself – is that display actual realtime?
juliansFree MemberLooks like others with the same meter have experienced the same
including one chap whose meter was recording gas flow when the meter was disconnected completely.
Looks like they start to give wonky readings when the batteries get low
multi21Free Memberjulians
Full MemberLooks like others with the same meter have experienced the same
Brilliant, what a shower these meters have been.
juliansFree MemberHave reported it to shell – they want me to give them daily readings at the same time for a week and then they’ll decide what to do – hopefully they dont just fob me off by telling me I’m simply using more gas…..
dont see how they can argue that the meter still counting up when the gas is switched off is anything other than a fault, but got to go through their script I suppose.
sharkbaitFree MemberStupid question, but have you checked that he valve has actually turned the gas off (i.e. tried lighting the hob)?
Just in case!!juliansFree MemberStupid question, but have you checked that he valve has actually turned the gas off (i.e. tried lighting the hob)?
Just in case!!not a stupid question – but yes, I did confirm that the valve turned the gas off. Tried the gas fire and the boiler.
oikeithFull MemberGas meters do have a battery so if the SMETS1 meter has been installed for awhile it could need replacing, Elec meters dont have this issue as they poach directly from the supply.
Your supplier should be aware of the an alert for low battery, but if the teams how answer the phones have access to this data is another question!
I guess there is the potential for gas to be in the pipe between the shut off valve and meter, but not to the extent youve record I would think.
juliansFree MemberGas meters do have a battery so if the SMETS1 meter has been installed for awhile it could need replacing, Elec meters dont have this issue as they poach directly from the supply.
its a smets 1 meter that was installed in 2011. its a libra 310p gas meter from Landis+Gyr.
The run of pipe between the shut off valve and the gas meter is about 30cm long, if that – so it surely cant hold ~3 cubic meters of gas.
juliansFree MemberYour supplier should be aware of the an alert for low battery, but if the teams how answer the phones have access to this data is another question!
we switched supplier since the meter was fitted in 2011, and as a result its not sending its readings back to base, we have to do it manually on the website – So I presume they havent had a low battery warning.
Andy_SweetFree MemberI had one go faulty a few years back. The call centre swore blind that they never go wrong, threatened to charge me for the engineer call out etc. guy comes to have a look at it “yeah these go wrong all the time”
juliansFree MemberI had one go faulty a few years back. The call centre swore blind that they never go wrong, threatened to charge me for the engineer call out etc. guy comes to have a look at it “yeah these go wrong all the time”
Yeah,I’m expecting a battle, but when the meter is still increasing even though the gas supply is closed off ,I reckon thats pretty clear cut.
It’s a bit sh1t that the meter starts to give erroneously high readings when the battery is on the way out.
ircFull MemberI guess I’ll keep on just sending meters reading via the website rather than getting a smart meter. What disaster they hsve been.
djgloverFree MemberHi, I was working in BG when we started rolling some of these meters out. at the time we thought the battery life would be about 10 years, some claimed 15, but it wasn’t certain by any means. 11 years seems like a good innings, but I dont remember anyone detecting this type of fault in testing. I know some of the guys at L+G well, so would be happy to pass details on directly, but unfortunately the argument over disputed consumption will need to be with your current supplier.
I would say generally smart meters are a good thing, I wouldnt be able to export solar to the grid or charge my EV cheaply without one, and hopefully we wont experience these faults with SMETS2, although I suspect the fault is down to the battery and metrology rather than the smets module.
andrewhFree MemberThe run of pipe between the shut off valve and the gas meter is about 30cm long, if that – so it surely cant hold ~3 cubic meters of gas
Depends. Is it over 356cm in diameter?
That would seems a little large for a domestic gas pipeFlaperonFull MemberI wouldnt be able to export solar to the grid or charge my EV cheaply without one
If you didn’t have a smart meter you could still export to the grid, but you’d also get a refund on the electricity you’ve used by driving your meter backwards, so I’m afraid that argument doesn’t stack up.
That the FIT rates are so derisory when unit prices for electricity are nudging 40p/kWh is hardly a reasonable state of affairs.
djgloverFree MemberThat would only happen on an analogue meter though, so rare these days! I am getting some seriously good export rates from octopus, average for today is 34p.
tthewFull Memberthey want me to give them daily readings at the same time for a week and then they’ll decide what to do
Sorry, I know this was yesterday and you have to do as asked, but I really can’t see how that will help unless they’ve got a week of comparable data to view it against from before the issue started.
juliansFree MemberSorry, I know this was yesterday and you have to do as asked, but I really can’t see how that will help unless they’ve got a week of comparable data to view it against from before the issue started.
Yeah it’s an irrelevance,given the meter is counting up when the gas supply is off. but they’re following their script,so I’ll go with it for now. Incidentally the current rate if consumption(as recorded by my faulty meter) would see me paying about £1000 per month for gas alone. Normal bill is £200 ish for gas and elec.
The meter reckons I used 53 cubic metres of gas in the last 24 hours
If they don’t play ball and get the meter fixed/replaced after this week, then I’ll be exercising my legal right to get them to send the meter off for independent testing.
I think they’ll agree it’s broken though before it comes to that.
juliansFree Memberbut I dont remember anyone detecting this type of fault in testing
Have a look on the money saving expert thread I linked to earlier, there are quite a few people with the same problem with the same meter (l+g Libra 310p)as I have.
jcaFull Memberwould see me paying about £1000 per month for gas alone. Normal bill is £200 ish for gas and elec.
That’s going to happen whether you have a faulty meter or not…
juliansFree Memberupdate – shell are putting in a new gas meter (and electric meter because they have to work as a pair) on Tuesday.
Need to see how they work out what our bill should be, given that the meter has been inaccurate for a while.
EhWhoMeFull Membersimilar here, British gas summer use in 2021 was 10800kw previous summer 4800kw, just no way we have use that gas, oddly the winter 2021-2022 is only 2000kw higher than previous winters…but still no idea why the increase over previous winters given this has bee a very warm winter
BG not really interested and say i must have used the gas…only gas we have is heating and water and the heating is off from april to sept
juliansFree MemberBG not really interested and say i must have used the gas…only gas we have is heating and water and the heating is off from april to sept
If you think the meter is faulty you have the legal right to get your provider to have the meter independently tested, at their cost if the meter is found faulty, at your cost if it’s found to be fine.
Have a look on citizens advice or which websites.
The topic ‘Gas meter fault?’ is closed to new replies.
