Viewing 6 posts - 1 through 6 (of 6 total)
  • Garmin 810 stuck in diagnostic mode
  • pete68
    As per title, but how the hell do I get back to normal screens. Even rebooting makes no difference. Many thanks if anyone knows
    Flaperon
    Check that a button isn’t jammed in.
    reluctantjumper
    Mine did that, you have to do a full factory reset to get it out of the loop. Can’t remember the buttons you hold down and in which order but it took 2-3 attempts for it to work.
    nakedrider
    Had similar a couple of times a few years back. I vaguely remember simultaneously holding the power & right key (I think) for like 1 minute (longer than you think you should).
    You’ve not got many options really. Hold some key combinations for a while and see if it restarts.
    Oh, and make sure the memory card is taken out. I had this cause a hang once so its worth getting it out of the way!
    jonnyboi
    The Garmin online chat support is pretty good, especially if you are in the UK.
    boobs
    My watch did that, then it heated up and died 🙁
    wasn’t an 810 on a positive note.
The topic ‘Garmin 810 stuck in diagnostic mode’ is closed to new replies.
