sirromj – Member
Seeing as I was only really intersted in gain I have never calibrated it.
Same with me. Not really that fussed about the height accuracy, so long as the gain is reasonable.
It’s never going to be perfect though. Barometers are affected by pressure changes, and GPS altitude is far less accurate than positioning.
In many ways topographical data correction that Strava does is perhaps better. Sure it’s not spot on as that 10 metre square you’re on may actually be 10ft higher or lower than the data plus it’s not fine grained enough to account for all the small undulations.
On the other hand though it may be more consistent. If it’s giving me the same kind of data between rides for the same device, and comparable with others then that’s good. Though I still find wild differences between other people on the same ride. More so in altitude, but even distance can be a mile or two out and many of us are using Garmins!
Oh, and on distances, there are differences if you use a speed sensor also. It’s more accurate as it clocks up wheel distance but may turn out to be more or less than expected compared to those just using GPS.
