Ive just started the process of using the two pack paint.
I had the old leyland floor paint down and while it looked great to begin with it started to loosen and deteriorate quite soon after. I probably should have done more prep than i did before applying it.
I got paint from regal paints, seemed quite reasonable compared to some.
Did loads of cleaning of the old floor, and tried to go over the whole thing with a wire hand brush.
It has the under sealer on it, I was expecting it to cure quickly but think the slab temperature was too low so its taken a few days to cure with a heater on most of the day.
Hoping to get the first coat of paint later today.
I think with hindsight I might have used a floor scrubber to remove more of the old paint and I would wait for a few days of warm temperatures before starting.
Depending on the current condition/make up of the floor you might need to do different prep, but thats probably the same for the one pack or two pack.
Im going to apply two coats of paint and hoping that it leaves me with the hard finish that will take a bit of wear.
It stinks though, I had neighbours coming down to see what I was doing, i imagined it being like the old bisto TV adverts 🙂
