Geometry is the same up or down so the leverage us the same.
The bracket itself is potentially slightly stronger upside down as it removes the potential of buckling. I guess how it joins the brace on to the l bracket might need considering but assuming its welded i’d say crack on.
Edit: actually what you really do need to consider is how you affix the worktop. You are putting alot of pullout force on the threads you might be better to drill all the way through and bolt. Would look interesting and the brace will give you a nice book end to work with. Or they’ll get in the way…
Edit2: the comment about leverage isn’t true it is actually a worse case but decent fixing i wouldn’t worry about it. Just don’t stand on it.
