Trying and failing to correctly set up a direct mount 2x SRAM front mech. Any help tips greatly appreciated.
With the cable removed, set the inner limit screw with the chain on the largest rear sprocket, set the outer limit screw with the chain on the smallest rear sprocket, connect the cable and adjust the tension so that with the chain on the large chainring and the large sprocket, the mech doesn’t foul the chain….
With the chain in any of the larger half of the sprockets, the chain will not shift from small chain ring to large……
Or, if I adjust the cable tension a little, with the chain in any of the smaller half of the sprockets, the chain overshifts the front ring
new cassette, chain, chain rings.
What could the problem be?
