Viewing 5 posts - 1 through 5 (of 5 total)
  • Frame pivot bushes
  • Premier Icon voodoo_chile
    Anyone tried to source or fashion some frame pivot bushes ?
    Any advice would be great
    Premier Icon Junkyard
    easy enough if you know the measurements
    Junkyard help me out
    remove bearing
    Get some digital vernier calipers
    Measure bearings Width Inner and outer
    Go to bearing shop give them the measurements
    Most bike stuff does use standard bearings but there are not always cheaper – eg Hope wheels ones are dearer from my local bearing shop than from Merlin
    How to guide with measurements on the side to enter data and get the bearing
    https://www.bearing-king.co.uk/how-to-measure-a-bearing.php7
    Might help of you say what it is for or from what bike otherwise it will be pick your size
    Possible use Igus bushes if there is some “slack” – think like the top cap on your Bottom Bracket or the bush in your shock
    Thanks junkyard it’s an old idrive main pivot bushings …so no bearings in the pivot point
The topic ‘Frame pivot bushes’ is closed to new replies.
