My dad has a Dutch bike which he, (inexplicably – I’ve ridden it, it’s bloody weird) loves. Problem is he’s getting a bit wary of slinging his leg over the top tube now he’s knocking on a bit. It needs that cutting off, but then reattaching lower on the seat tube to down tube to provide some triangulation, I don’t’ reckon this designed as a step-thru with an added top tube.
Any suggestions in/near Cheshire or any volunteers? Don’t think it will need an artisanal frame builder, just someone who can mitre and fine weld or braze it on. We’ll just black enamel over any paint issues.
edit – I’m looing at it now, and wondering if a gusset between the down tube and head tube wouldn’t also be a good idea. 🤔
It might be a bit awkward if the seat tube is butted as the wall thickness will be too thin where you plan to reattach the top tube. Even if it doesn’t break it might extremely flexible.
I’d be 99% certain that thing hasn’t got butted tubes… 🙂
If you struggle to find anyone properly local then I could do it, but wouldn’t be for at least 6 weeks (I’m a bit further north up the M6). Have got frame jig, brazing and mitre kit. Probably have some 28.6mm Columbus cro-mo tube.
It looks like the ‘ladies’ version isn’t fundamentally different to the ‘mens’ version so it would probably just be a case of taking out the top tube, cutting it down and welding it on further down.
As has been alluded to though, the cost of doing that probably outweighs the value of the bike and buying a replacement built to the spec is probably the better route.
Embarrassingly, I forgot to follow up my question. Thanks everyone, particularly @mick_r (might take you up on that) and @dave_h for the photo of the ladies version, that reassures me the basic idea is sound. 👍
Could probably reuse the top tube to fit a strut low down like the ladies version, together with a short tube to triangulate the top of the HT to that lump of a downtube.
