I own a DT Swiss wheelset (240 hubs front and back) bought new with around 800 miles on them. This is the second set of these hubs that I have owned. The front hub has started to get a bit notchy which is really surprising as I though the Japanese-made bearings in these could go for 1000’s of miles before needing attention. Indeed, my last pair never needed anything doing to them in the thousands of miles I put on that bike before I sold it.
The only variable I can think of is that on my current bike, I’m running a Fox 34 fork with the Kabolt through axle. The torque spec on the axle is 17nm, which I consider to be really high for a through axle. I set it at 15-16nm just to give a bit of leeway but I have seen some of the newer Kabolts with a torque rating of only 9nm.
Has anyone else run into the issue of premature bearing wear with this setup? Should I dial down the torque on the Kabolt?
