Thanks tdog, but being in Oslo, Norway I don’t think they will help me much. I’ve just taken the shock off, took it apart, cleaned and applied new lube (used 15w suspension oil, I know it’s not ideal and I will replace it later on with proper float fluid). I was trying to understand if the transfer port (or rather a dent on the air sleeve) was blocked.
Unfortunately after pumping the shock back up, cycling it every 50psi, nothing has changed.
100 – 120 psi are closest to the feeling and sag I’m going for, but that pressure seems too low since as I mentioned I weight 90kg. Is it possible that this shock is a low end shock and should not expect more from it?
Are there any other Sensor owners out there? What pressure are you running?
Or maybe just someone with the same shock?
This is the information I’m getting by custom tune id:
2016, FLOAT DPS, P-S, A, 3pos SV, GT, Sensor Elite, 7.250, 1.750, 0.4 Spacer, CM, RM, Climb F, 10291C/396C Logo
