I’ve never owned any Fox forks before (all my previous forks have begun with the letter “M”) but I’ve recently aquired a bike which has Fox 34 Talas Factory FIT CTD forks (2012, I believe, 26″).
I’m about 70kgs and Fox recommend something like 130psi for this weight – well, with that pressure the things are practically solid. To get any sort of reasonable sag I have to run them at 40-50psi, which seems weird. With that sort of pressure they can get full travel but before I either throw them out and go back to Marzocchis or tear them apart in an attempt to figure them out has anyone else had this experience?
They’re not exactly plush either…….
Also, has anyone fitted the later TALAS assembly (2014) into these earlier forks and, if so, was it worth the trouble/expense?. Any other info you can give me will be gratefully received!
