I switched to short offset forks in 2015.
It suite long slack bikes IMO.
Is your Befe a 29er, long and slack (ish)? –
I prefer 42mm / 160 / 29er Lyric on my XL Geometron 62 degree head angle approx.
Back in 2015 I had 650B Float 36 on, I preferred 37 offset (or was it 36) – basically using the Fox 36 26″ CSU and 27.5 lowers.
When I first went to 27.5/29 [mixed wheel sizes], I tried 51mm offset / 29er 160 forks and felt I had to push the bike over too far in corners for singletrack compatibility. It felt too slack. The 42 offset Lyric fixed that.
Shorter offset = more trail, so more stability. calm. I think that will be. nice touch on a rowdy hardtail.
Shorter offset also meant that the bars needed turning a bit more when steering the through slow Singletrack – that helps thread my 820 bar between the trees.
The one disadvantage, I’m told, is at high speed on a tight track riding blind – the bike will not change direction quite as fast. I’m not fast enough to notice that but it partly explains why the DH guys run longer offset [although a few are going shorter in the WC arena with the Mojo MORC – and differences in dual crown fork flex lead too different actual trail too, so there numbers can’t be compared directly with SC forks].
The upside is shorter offset (more trail) feels more “calm”
According to Honda testing with Minnaar back in the day resulted in the decision that stem length should be less than offset. Interesting.
neilB
