Viewing 5 posts - 1 through 5 (of 5 total)
  • Fork/Disc brake rating
  • jayx2a
    Member
    I was choosing a new front disc but was mentioned that forks have a max size rotor they are rated to be able to use without any issues with flutter or twist.
    I cant find this info anywhere for mine!
    Fox Rhythm 34 Float, GRIP adjustable damper, E2 tapered steerer, G2 Geometry w/51 mm offset, Boost110, 130 mm travel
    Tried looking at the FOX site but couldnt really find anything relevant!
    I’m on 180mm (the forks have 160mm + adaptor), but was looking at 203mm, but don’t want to get any negative effects!
    Premier Icon orangespyderman
    Subscriber
    I seem to recall the I noticed the Fox website states 180mm max on the Fox 34s that were supplied OEM on my Jeffsy. The bike was supplied, again OEM, with 200mm front rotor…
    I wouldn’t worry too much.
    Premier Icon timoth27
    Subscriber
    Try putting your serial number in here.
    https://www.ridefox.com/fox17/help.php?m=bike&ref=findbyserial
    jayx2a
    Member
    Just checked the above and it says on FOX website:
    Maximum brake rotor diameter for all FOX forks except Step Cast 27.5in is 203mm. Step Cast 27.5in forks have a maximum rotor diameter of 180mm.
    Subscriber
    That’s interesting what’s yours?
