Home Forums Bike Forum Flat mount brakes rotor size
Viewing 7 posts - 1 through 7 (of 7 total)
  • Flat mount brakes rotor size
  • neilnevill
    Flat mount is new to me so I’m after confirmation of parts compatibility/ need before orders go in for a bike build.
    Titus goldrush frame
    Shimano grx rx400 rear caliper
    Does a 160mm rotor fit the frame and do I need to also order a rear fm to fm +20 adapter in order for the caliper to fit the 160mm rotor?
    Thanks
    sillyoldman
    Depends on whether it’s a native 140 or 160 mount.
    if the former, it needs the adaptor, if the latter, it bolts directly on.
    neilnevill
    Ha! Makes sense.
    This one
    https://www.cyclesolutions.co.uk/components/brakes/shimano-grx-rx400-hydraulic-disc-brake-caliper–rear__52698
    I can’t see of it says 140 or 160…I’m guessing 140 with no adapter.
    simondbarnes
    The caliper is irrelevant, it’s the frame that determines the native rotor size.
    neilnevill
    Is it, great,  I shall check with px then.
    swampi
    Pretty sure the gold rush is 160 without using a rear adapter
    Onzadog
    Have you got the frame yet? Hope website has some technical drawings that give you the measurements to confirm which type of mount the frame is
