I just killed the track pump in the garage and was going to just order a topeak mountain but then I thought, I could take the mountain from the car, and get one of these tubeless flash charger doohickeys for the car, could be useful sometimes…
But most times, when I use the pump that lives in the car, it’s to knock a few psi into a tyre at the start of a ride. So I don’t want to have to charge up the inflator pump doofer every time, just to add effectively 2 or 3 pumps worth of air. And I gather that’s how most of them work, you can’t bypass the air can.
So… are there any that work just as well as a normal pump for normal pump jobs, while also doing the tubeless blaster thing? Or, I suppose the other question is, am I overthinking this- will it still do that job OK?
