One bit of advice on the measure twice, cut once thing; the most reliable way I’ve found of doing it is to fit the crown race, then fit the forks, spacers and stem. Once you’re completely happy, draw a line around the steerer at the point where it pops out of the stem (or any spacers you have on top of the stem) and cut 5mm below that point. This way, you have a definitive mark, and you know it’ll fit. This is the best way to do it if you have changed any components other than the forks (ie, fitted a new headset) or if the forks are a longer axle-crown length.
I remember once visiting the Future Publishing batcave, where the resident testbod was chuckling over a steerer that a staff writer had tried to cut for his new Turner. It was a: cut in a spiral, as he’d not used a guide, and b: 10cm, as he’d measured the headtube and got cutting.
[edit] by the way – star fangled nuts need not be reused. Rock Shox forks come with a new nut, most bike shops will just give you one, and banging out the old one from your old forks is a pain in the neck. Not only does it look really shady for anyone thinking of buying them off you, but star fangled nuts should not (Apparently) be reused. I don’t know if I subscribe to that last argument, but for 50p, you might as well tap in a new one. HTH
