Viewing 39 posts - 1 through 39 (of 39 total)
  • Fitting a b*stard of a tyre!
  • pc2017
    Member
    Currently sat here red in the face after trying to fit some tyres.
    Managed to get the front one on after bout 20 mins of messing about and now the rear is doing the same and also being a pain in the arse.
    I have put on countless amounts of tyres over the years but nothing like this, the tyres are Schwalbe tough tom and I am using pedros yellow levers which are usually excellent.
    Any tips on this, I can get it about 90% on.
    Premier Icon Poopscoop
    Subscriber
    You mean just getting them into the rim itself or inflating tubeless?
    pc2017
    Member
    Just getting the tyre on to the rim.
    mariner
    Member
    Sounds as though you might be missing the ‘well’ that the tyre has to sit in.
    Have you taped it flat inside the rim?
    CraigW
    Member
    Best way is to use a ‘bead jack’ eg the Koolstop Tyre Mate. http://www.davemellorcycles.com/koolstop-tyre-mate/p19304
    Premier Icon scotroutes
    Subscriber
    Nah. The best way is to learn to do it properly.
    pc2017
    Member
    Thanks. That will be getting ordered this evening!
    pc2017
    Member
    Is there a proper way to put tyres on? My ‘wrong’ way has worked for years on numerous wheelsets.
    maybe is cause these are carbon rims?
    CraigW
    Member
    Some tyre and rim combinations are super tight, there’s no way to fit them without using tools. Schwalbe Marathon Plus on narrow road rims are the worst I’ve tried.
    The bead jack tool lifts the tyre up into the rim, so less risk of damaging the tube etc.
    Premier Icon matt_outandabout
    Subscriber
    OP, what technique do you use currently?
    joshvegas
    Member
    Pfffft
    Come and fit a steal beaded road Tyre to the vision 30s on my road bike.
    So tight it just tore the rubber off the bed (not kackhandedness)
    joemmo
    Member
    Have you tried a bit of soap and water to help the bead slip over?
    Premier Icon chakaping
    Subscriber
    Ignore the tossers telling you you’re doing it wrong.
    Get a metal DH tyre lever and maybe use fairy liquid if necessary.
    Some tyre/rim combinations are just horrible, regardless of technique.
    Premier Icon tjagain
    Subscriber
    I always thought this that some tyres really needed tools and couldn’t be put on by hand. a pal told me I was wrong so I challenged him. He fitted a tyre by hand that I struggled to do with levers. Its all about getting the tyre into the well and working the slack to the final area you want over the rim
    Premier Icon eskay
    Subscriber
    Fitted a Continental Tempo tub to a disc wheel last night, my thumbs are still raw. It always gives me a mild heart attack when a £60 tub is half on/half off and it looks like a physical impossibility that it will ever sit on the rim!
    paton
    Member
    [video]https://www.youtube.com/watch?v=mBa88zZossE[/video]
    Premier Icon charliew
    Subscriber
    Warm the tyre up, grease the tyre sidewalk with something like swarfega
    philjunior
    Member
    Like tj says, you shouldn’t use levers to put tyres on. With the right technique (bead into the rim well, stretch it round to give as much slack as possible) you don’t need them for any combination. All levers will do if used when fitting is damage stuff.
    epicsteve
    Member
    I use one of them for Schwalbe Marathon Pluses which can be very tough to fit – just glad that they pretty much never puncture! The tyre jack thing makes the difference between a nightmare struggle with the tyre and being able to fit it in seconds.
    Subscriber
    DO.IT!!!
    I’ve fitted loads of Marathon Pluses on all sorts of shit rims and I’ve never heard of a “bead jack”.
    julzm
    Member
    As someone said above, move the bead into the very middle part of the rim. It’s slightly less diameter and therefore makes the tyre slightly looser to get over the rim.
    This makes a massive difference. We’ve a set of Carbon wheels that are bloody impossible to get some tyres on without losing some fingers in the process, however using that method makes it quite a bit less painful.
    Subscriber
    Having not seen one of those tyre Jack/mate things in use I found this slightly amusing video demoing it:
    here
    In essence it gives you plastic thumbs with no pain receptors! 😀
    Initially I thought it was a bit daft then I remembered how long my fingers hurt the last time I put a difficult tyre on!
    That said,I don’t like using even plastic tyre levers as I’m far too precious about marking the rims or rim logos! Sad I know. 😆
    Premier Icon theotherjonv
    Subscriber
    also – when fitting the tyre, start opposite the valve and leave that till last. I know it’s the opposite of what most people have been taught, but then you have all of the well to get the bead into, instead of losing part of it to the valve part of the inner tube or the tubeless valve.
    Then when you get the last bit over the rim, you need to push the valve into the tyre a bit and then pull back out to ensure the bead’s properly seated, but that’s still easy.
    Premier Icon Kamakazie
    Subscriber
    Had a right pain with some tyres last night. I think I should have finished at the valve as noted above because they really do screw things up.
    Wide rims with shallow rim well’s really don’t help though.
    deadkenny
    Member
    +1 tyre bead right into the well. Years of fitting and struggling with tyres at times and didn’t believe it, then sudden revelation by trying it. Same when taking them off.
    Wide rims are a little more of an effort but still can get them on and off pretty easy now. Lever just used for the last bit. Bonus with wide though is I find they seat tubeless far easier.
    chakaping – Member
    Not with carbon rims!
    Subscriber
    Mine would be OK on carbon actually, it has a plastic coating…
    https://www.amazon.co.uk/Icetoolz-Downhill-Lever-Aluminium-Carbon/dp/B006WJS8Q6
    mattyfez
    Member
    My carbon rims are an absolute sod to fit new tyres into. Rons and ralphs.
    Once fitted they seem to stretch a tad and are then a bit easier to refit.
    I use a combination of brute force, hard metal levers and the following method, but there’s always swearing involved.
    [video]https://youtu.be/-XUFVrl0UT4[/video]
    But as above, once you’ve got it mostly on, it’s critical to keep the beads in the central lowest part of the tyre well, working around several times and repeating as nessesary to ensure the tyres not moved from the centre.
    natrix
    Member
    BITD I used to use toe straps to help get stubborn tyres on, (but I haven’t got as much grey hair as the chap in the video.) I expect insulating tape would work as well 8)
    Premier Icon IHN
    Subscriber
    AFter 20+ years of fitting tyres, including a reasonable amount of swearing, I never knew about the rim well thing until now.
    Every day is a school day.
    avdave2
    Member
    After really struggling at the side of the road with my first puncture on my road bike, not bad for just over 2 years of riding, I decided I’d just try a few different techniques when I got the bike back home. Basically what I found to work were the approaches above. Putting the wheel on the floor and pushing down around the rim working towards the valve at the bottom. From struggling with 3 tyre levers I found I could now do it with no tools at all. Of course it could be very different in January in ice cold rain
    pdw
    Member
    I’ve done some pretty tight tyres with just my hands, making sure it’s in the well, starting opposite the valve, and working the slack around, but I’m not afraid to get the (plastic) levers out rather than battling it out to prove a point.
    When resorting to levers, do all the stuff above as well, and just try to get a little bit more bead on with each go. As you lever it, push the bead up the lever with your thumbs so that it stays as close to the rim as possible when levering.
    kayla1
    Member
    Oooh, I like that jack thinger. No more hot thumbs!
    ChunkyMTB
    Member
    What TJ said.
    deadkenny
    Member
    chakaping – Member
    I wouldn’t be worried about scratching, it’s the rigidity of the lever. Plastic levers snap. Metal probably won’t, in which case the rim might crack instead. Having had a carbon rim crack on a simple bunny hop on a fire road, I’ve got no faith in them.
    [video]https://www.youtube.com/watch?v=KigNbUxx6X8[/video]
    Shite.
    Premier Icon timber
    Subscriber
    I have some assymetric rims and it makes it quite easy, when approached from the correct side anyway.
    Had some years ago that were a pain to fit, pumped them to 50psi so that I could at least eliminate the chance of a pinch flat and dreaded the day they would puncture. Well loose by the time they did.
    Premier Icon gdm4
    Subscriber
    Dave Mellor Cycles logo………brilliant!
    pc2017
    Member
    Problem solved..
    After purchasing the koolstop tyre mate and still having a nightmare I sacked the tyres off and purchased some new Nobby Nic folding tyres which I had on in approx one minute.
    Never again am I purchasing the originals!!
    WTB and stans dont play nice from my experience….
    shame, as I like the tyres, and the rims….
The topic ‘Fitting a b*stard of a tyre!’ is closed to new replies.
