Sorry if this is a dumb question, but I’m finally going to dip my toe in the tubeless waters and there’s something I don’t understand…
All the instruction guides I have seen use one of two methods for the rims:
a) Adhesive rim rape over the spoke holes with a seperate valve which clamps onto the rim.
b) A rubber rim strip with a built-in valve.
I understand how both approaches work, but what I don’t understand is which approach I should use.
Do they give exactly the same results? Or is there a reason why you should use one instead of the other?
I am using “normal” Mavic rims if that makes a difference. Thanks.
