Hi everyone
hope you’re all well
have recently purchased and received an on one fatty trail with the oversized chai stay problem (whoops)
given current situation I’d rather not go through returning if there’s a workaround so
problem is this
frame is 100mm bb
chainstays do not clear a 100mm crankset
apparently they were designed to clear 120mm bb crankset.
i have limited budget to amend the issue
what cranksets might be able to be successfully ’spaced’ out to 120mm using a 100mm bb
im already planning on using widest bb cups I can plus extra 2.5mm bb cup either side (poss more if I can use the saint Bb I’ve got)
over to you hive mind
