I thought this was pretty commonly accepted about most Maxxis tyres as they tend not to feature transition knobs.
It isn’t really a transition knob thing, which is why it’s not a universal thing with Maxxis tyres. I think a lot of the time a transition knob is a worse solution to the grip/slip/grip issue than an adjustment of the tyre shape, centre knob design and side knob design to change a tyre from a ‘commitment tyre’ to one that’s more tolerant of poor technique, because a transition knob can causing mud clogging.
The original High Roller is more of a commitment tyre than the High Roller 2. I wouldn’t say the Minion DHF is like this at all. The Minion DHR2 is slightly like this but not a lot. I do notice it with the HR2 – after the first sketchy corner I ride properly! 😉 The Shorty is extremely easy going, really doesn’t care if you lean it or not.
If a tyre has a clear channel between the centre and side knobs then it may require more committed riding but if the centre knobs are shaped for cornering (like a DHF or Shorty) then it’ll be pretty easy going, or if the centre knobs reach a fair distance into the channel and are still slightly shaped for cornering (like a DHR2). If the centre knobs are just made for braking and not turning (like an HR2) then you have to lean to the side knobs to make it turn.
