Why is it going to be any more susceptible to warping than any other engineered wood? The softwood is literally a thick veneer and the main structure will be ply, the same as any other.
Performance
As solid doors are made of whole intersecting pieces, there is an inherent strength that comes from the construction. They are, however, susceptible to environmental changes such as variations in humidity and temperature. Exposure to factors like these can cause a solid door to warp or bow, making it twist and gradually lose shape.
By having layers of timber running in different directions, an engineered core is able to evenly distribute any stress applied to it. This makes an engineered door far more stable than its solid counterpart. This modern construction technique also provides better thermal insulation than that offered by more traditional methods.
Pros and cons
Solid internal doors and external doors, particular hardwoods like oak, will always have a premium allure to them. There’s an undeniable attraction to products with a solid hardwood construction, but they might not always be the best choice for your project. It’s highly likely that an engineered set will out-perform your solid option for less money, and, as building regulations call for better thermal insulation, your final decision could end up being a no brainer
https://www.aspire-doors.co.uk/blog/the-difference-between-solid-and-engineered-doors/
