So how long on average where you getting out of it in the Reflex setting?
I reckon left on Reflex you’ll get 60-70% of the quoted run time, so around 2hrs on the 3hr setting and 4hrs on the 6 if that makes sense.
I run mine in PGM-1 but click the switch to the low power mode when climbing. It’s more than enough for that. In Reflex it says 3:01 on 100% charge when turning it on, but not sure you’d get that unless your ride profile is all up, all down, all up, etc…
Yeah basically what I do. You still get about 500 or so lumens for climbing, which is more than enough. As soon as you’re on the flat or going downhill, knock it up to Reflex and it sorts itself out (albeit the battery runs out quicker than stated).
Its almost too bright. Great for techy downhill bits, but quite possibly far too bright on its highest setting for just riding about.
Quite agree. Which is why, to me, even though the 6Pack is only slightly more expensive, the extra brightness is totally redundant, however…
Used my six pack for the first time tonight, chose it over the maxxD simply because I thought the extra lumens on a longer run time was worth the extra as I do endurance events.
As he said, if you do endurance events especially solo, the battery life on the 6Pack comes into its own. You can get roughly 1000 lumens for a solid 12hrs FFS!
Next question…
Is the 6Pack worth an extra £35 ?
£55 at RRP. If you want to have a play with one though, pop by the shop you’re more than welcome to give it a go.
