How much did that set you back and how long has the fix lasted?
Lots but also replaced the turbo at the same time.
The manifold I took to a local machine shop and the refaced it for £50 so that the mating surface looked good as new. New gaskets & manifold nuts from VW were something like £75. That was coming up to 3 years & 30k Miles ago i think. I did the work myself and got very lucky that none of the exhaust studs snapped in the head.
Mine is a BNZ engine code which is known for warping manifold, different codes have different type of manifold and some are known to crack instead.
Our symptoms were fumes in the cab and an oil leak from the back of the turbo where it mounts to the block.
