I was able to try a Defender for a weekend before buying my first one. Although I really liked it I was still worried initially, knowing that I’d have to live with it for a few years, but I’ve rarely looked at another vehicle since.
I know they’re flawed in many ways, but that’s part of the appeal, and they just suit me. I find the driving position to be really comfortable, but I’m of slim build, so I’m not squashed against the door.
I’m on my third now, which I’ve had for 11 years and 200,000 miles. It’s a TD5, so a bit different from a new one.
Mine hasn’t been too expensive to run, although it can’t be run on a shoestring budget. I go to an independent specialist for all servicing. Apart from normal servicing it’s needed new discs, callipers and steering components. A few parts fail at regular intervals – light switch, fuel filter. I’ve also had some injector washers and an air-flow-thingy go, plus the rear silencer, Tyres last really well – I get around 100,000 (road) miles out of them. I would say corrosion can be the biggest problem, and from what I’ve heard the new ones may even be worse.
The engine in mine is great – loads of low-down grunt, and you can drive it on a trickle of throttle. I had it remapped to improve fuel economy, and although I rarely use the extra power it’s also pretty fast now. It also handles pretty well for what it is. Although there’s a lot of chassis lurching, the anti-roll bars keep things under control, although you wouldn’t want to overcook things in a big way. I tend to drive slower now than I used to, and keep within speed limits, but I used to drive fairly quickly on Scottish west coast roads.
From what I can tell depreciation is low.
I happily live with all its quirks, and don’t mind the rough edges, although it definitely is different from a modern vehicle.
