- This topic has 92 replies, 52 voices, and was last updated 4 years ago by endoverend.
Engine Braking?
jamesozFull Member
Any driver of a manual car that has never used engine braking either has never driven anywhere hilly or is a terrible driver.
GlennQuagmireFree MemberHence the ‘use low gear’ signs on steep descents.
But you’re not stopping, just trying to regulate speed. If you need to stop, then let the brakes do exactly the thing they were designed for.
molgripsFree MemberWhen I was leaning to drive I cooked my brakes
When was that? How old was the car?
Not really related to the skidding on ice issue.
DracFull MemberThey only make the things, perhaps they know how they should work…
Indeed. Which is why mine have has engine braking option on the gear selection.
submarinedFree MemberWhen was that? How old was the car
1998.
1998 Polo, 4 up on the approach to Friston from the East.
Take a look at most modern family hatches and they have small discs all round (some even still have drums on the back)
You can’t change the laws of physics, with a full car it’s relatively easy to cook the fluid or pads on most modern cars.
There’s nothing wrong with engine braking. It’s better than pumping unnecessary heat into the braking system.slackaliceFree MemberReference the abs and traction control in racing cars, I seem to remember the FIA banning such driving aids in F1 because they were deemed to aid the driver too much. Or am I thinking about something else?
Either way, moderate engine braking in slippy conditions enables speed control whilst maintaining drive through the driven wheels. Also using 2nd gear to start moving in icy conditions reduces the chance of wheel spin that is more easily achieved in 1st gear.
TallpaulFull MemberThis thread neatly highlights why driving in the snow is best avoided. Even if you think you know how to control your car on a slippy decent it seems highly likely the numpty behind you hasn’t got a clue!
HoratioHufnagelFree MemberThe instruction manual for my car explicitly warns against using engine braking. I suspect others are similar.
B.A.NanaFree MemberThe instruction manual for my car explicitly warns against using engine braking. I suspect others are similar.
In everyday driving Continuously using the engine to brake rather than the brakes to brake I expect will put undue wear and stress on the engine, so to be avoided. However we aren’t talking about everyday driving we are talking about exceptional circumstances. Also I think using heavy engine braking at speed is a bit different to using the engine as a ‘crawler mode’ or to regulate slow speed in snow (the assumption being that if you’re facing downhill in snow then you shouldn’t be going very fast in the first place anyway).
scotroutesFull MemberThe instruction manual for my car explicitly warns against using engine braking. I suspect others are similar.
What car would that be? And how do they advise you drive down a road steep enough to have “Engage Low Gear Now” signs?
thegreatapeFree MemberEngine braking can mean different things to different people. To some it means going down a gear, letting the clutch out so the engine revs high and then the car slows – I was taught this was not a good thing. Then there is gentle adjustments on the throttle but in the same gear to adjust the car’s speed as necessary – this was called acceleration sense when I was taught to drive (but I have seen it referred to as engine braking) and was considered a good technique.
The latter works particularly well on my Triumph but I can confirm it only does it on one wheel.
SandwichFull Member@colp I think you missed the bookcase. They’re the biggest sellers.
wobbliscottFree MemberUsing engine braking to actually brake is not really the done thing these days as it’s totally unnecessary – does not harm to the car, but just no point. Modern day brakes are so good no assistance form the engine is needed. So going down the box and engine braking in every gear is pointless. Just brake to the speed you want to get to and put the car in the right gear when you get there.
But using engine braking to regulate your car’s speed when going down a long steep hill or down an icy or slippery hill is totally the correct thing to do. You still see signs at the top of long hills saying ‘use low gear’ or something along those lines, to regulate your vehicles speed and reduce the use of wheel braking.
martinhutchFull MemberI also have a BMW so when faced with ice and snow, the only driver activated control that is of any use are the hazard warning lights. Closely followed by the airbag
You can generally use the car bumper two inches ahead of yours to regulate your speed.
AlexFull MemberI’m not one of those BMW drivers Martin 🙂 In fact I let people out and refuse to practice passive/aggressive ‘bumper humping’. It’s the surprise on the faces of the people I try and be nice too which hurts the most 😉
Anyway as you were. Our (un-gritted) road was properly icy this morning. It’s also on a hill. I’ll see how the whole thing plays out at 5am tomorrow morning…
EdukatorFree MemberFlaperon +1. It’s all changed now though, the only choice in the Zoé is do I use D or mode B.
Edit: and in fact you don’t get the choice because mode B doesn’t work when the battery is cold.
chestrockwellFull MemberI have nothing to add except bravo to the OP for dangling this cheeky bit of catnip at STW.
spooky_b329Full Memberdown steep hills in snow I’ve always let it free in 1st gear and feathered the hand brake. No idea if it’s best practice but always worked so far
Bad practise…vehicles that have dedicated handbrake shoes (such as a drum inside the disc) are not designed to do anything but hold the car stationary, so can overheat very quickly, or wear out very quickly. Its a problem in delivery vans when the drivers get into the habit of using the handbrake and starting to get out before the van has fully stopped.
Engine braking seems rubbish on modern cars, I think its to do with the EGR valve opening. However if my van works out that I want it to engine brake (1st gear, slow start and feet off the pedals), I can go down a 20% gradient near me (1 in 5) without touching the brakes, thats 5.5 tons of camper and horse trailer so its nice knowing that you don’t need to cook the brakes and then find them lacking when needed.
wobbliscottFree MemberDon’t know about vans but heavy goods vehicles use engine braking all the time and since Diesel engines don’t do engine braking as they don’t have a throttle body, then they have a specific system that creates engine braking in the absence of a throttle body. Clearly they’re very heavy so more need to reduce heat built up in the brakes. Cars tend to be massively over braked….even bog standard brakes fitted on small cheap cars can generate in excess of 3000HP of braking power so not so much of a problem in cars.
Definitely of use when descending long hills. Not so much for just slowing down for the traffic lights. And is better to use on icy slopes as you’re not actually braking…the wheels are still being driven just at a different speed than the car so less likely to induce a skid as you could if you use brakes – ABS or no ABS. Just a bit more gentle.
spooky_b329Full MemberThere are various driveline brake systems on HGVs, some are a bit rubbish, others are better. Electromagnetic retarders and exhaust brakes are common, US trucks often can change the valve timing so that the engine turns into a compressor and these can create lots of braking torque (jake brakes).
My van doesn’t have any of those, I wonder if it just closes the EGR or something as the revs climb over a certain threshold.
prettygreenparrotFull Member‘How to go down hills in snowy conditions’?
Slowly and with snow tyres. I found in snowy and icy conditions things can go from seeming pretty slow to ‘arrrrgh’ surprisingly quickly.
trail_ratFree MemberYou can’t change the laws of physics, with a full car it’s relatively easy to cook the fluid or pads on most modern cars.
Easy is a strong word. Sure it’s possible if your driving like a dick or your brake system needs over hauled.
But not something ive ever managed….and I’ve been over some steep and warm roads in heavily loaded vehicles…..
So by that definition it’s hardly easy.
As for engine braking – waste of time in the van – stick. It in second and try to go down a hill and it just run round the rev counter till it’s hitting the far side. It’s simply too heavy for the engine to retard it.
spooky_b329Full MemberYou need first gear trailrat. Although I’m sure my 2013 has more engine braking than my 2005 (same basic engine but ECU map will be different). First gear may be a bit lower as it’s a 6 speed versus the older 5 speed.
trail_ratFree MemberAlso worth remembering it’s rwd. The last thing I want to do is lock up the rear by jamming it into first on a slippy descent.
I use the brakes and the brakes are quick and easy to change designed for the purpose of stopping the vehicle. But I also fitted weather condition suitable tires for the bad weather which makes more difference than which friction plate you want to wear out.
like when I ride my bike I don’t drag them all the time -which must be largely why I don’t have the issue a significant number on here have with hope brakes.
I did fit brakes off a 2006 model though for more out and out stop power …..they are about 40mm bigger od and bigger calipers.
Meanwhile when I’m using my land rover off road in low traction situations I will use the engine more because it’s a different set up and not so likely to spin me….plus the engine actually retards usefully.
walleaterFull MemberI have nothing to add except bravo to the OP for dangling this cheeky bit of catnip at STW.
Ha! It was a genuine question, but the selection of replies on here sums up why I asked it 😉
Although in all seriousness, the whole ‘you only engine brake with one wheel’ didn’t make much sense to me. I just figured that the relationship between the engine, diff and wheels was pretty well the same regardless of speeding up or slowing down.BearBackFree MemberInteresting thoughts above.
Fwd car, open diff.. I guess perhaps that might be the case. But only if one wheel gives up traction?…. Then if it does go to one wheel then presumably it’s providing breaking to the wheel with traction?
Esc/stability control would also presumably monitor this and make corrections – if your talking a reasonably decent car post what, 2010?
Talking of esc, (summer tires club aside) this could well be part of the issue with cars not being able to get started up the icy hills. with this week’s conditions I’ve tended to switch esc off at launch in deep slush, ice etc as it stops the car getting bogged down in computer braking confusion. Back on again for driving though as presumably it’s more than just a **** light.pocpocFree Member2 pages on a snow driving thread and only a half mention of winter tyres? STW letting me down today.
Surely the answer is a full set of winter tyres and carry on as you would in summer with no loss or grip?
owenfackrellFree MemberPetrol engines produce more engine braking as they are pulling a vacuum when the throttle is closed. Diesel engines don’t do this when the throttle is closed. In a petrol you vary the amount of air entering the engine and the ECU supplies the fuel where as in a diesel you vary the amount of fuel you put in and the engine draws as much air as it needs. Diesel engines have a dedicated vacuum pump that creates the vacuum needed for the brakes. Diesels engines do produce engine braking just not as much.
As said above engine braking is used to control speed rather than actual bring it to a stop.johnnersFree MemberDiesel engines don’t do engine braking as they don’t have a throttle body
I definitely get a significant braking effect with the throttle closed on downhills (320d auto), I don’t know what’s doing it though.
*edited for clarity
DigbyFull MemberI was once recommended to put the car in reverse gear when trying to set off and negotiate the likes of downhill slippery compact snow or icy patch. Then, rather than jamming the brakes, locking them and sliding you would bring the clutch up and the vehicle would descend very slowly but without skidding and sliding into the curb or worse another vehicle in front. Not sure if this actually constitutes engine breaking! 🙂
Clearly not great for your clutch long term, but I’ve used the technique on a couple of occasions and it does work very well.
Also useful to know how to turn into a skids and +1 for winter/all season tyres.
Probably not worth teaching Winter driving skills for much of the UK though … these days we only seem to get a few days of actual winter!endoverendFull MemberI just figured that the relationship between the engine, diff and wheels was pretty well the same regardless of speeding up or slowing down.
As a complete sidetrack but related to this point…in the world of digital car racing/ sims ie: Forza 7 (if we accept the thinking that they are evolved enough to have a strong relationship to reality through their modelling) – then when you upgrade your car to the full ‘race diff’ then you get independently adjustable locking thresholds for acceleration and deceleration rather than a diff with set presets, and they can have an affect on on-limit grip both into and out of corners. So my thinking is that it depends what type of diff is in the car (probably very basic in most cars) as to how it would behave in deceleration and it’s ability to lock a wheel. I use the digital example as although I’ve been in a variety of fast sports cars on track at limit, I’ve never found myself thinking much about the diff unless it’s blatant ie: the way a Megane RS pulls into the apex under acceleration…perhaps a true real world driving god with deep experience of on limit chassis behaviour will be along to help out here….puts kettle on.
philjuniorFree MemberThe diff would mean you only achieve the braking force of twice the minimum on the driven axle(s) assuming open diffs all round.
Also, if you were to lock up/stall you might not restart the engine under extremely slick conditions, which would lead to one wheel locking up. This could be even trickier if you have an LSD, and will make things very tricky on a RWD car – even under conditions with the engine running there’s all sorts of contraptions to reduce engine braking and avoid a spin.
The engine does give a bit of control over speed, but for stopping you’re best to just dip the clutch and brake appropriately I would think. That said, you can probably modulate engine braking better as the force available is far lower so as long as the driven axle has most of the weight over it, it still may be useful in practice/away from driving gods.
scotroutesFull MemberSo, to summarise…
You should never, ever use engine braking, except, of course, to control your speed.
And it doesn’t work with diesels, except when it does.
Seems clear.
philjuniorFree MemberPetrol engines produce more engine braking as they are pulling a vacuum when the throttle is closed. Diesel engines don’t do this when the throttle is closed. In a petrol you vary the amount of air entering the engine and the ECU supplies the fuel where as in a diesel you vary the amount of fuel you put in and the engine draws as much air as it needs. Diesel engines have a dedicated vacuum pump that creates the vacuum needed for the brakes. Diesels engines do produce engine braking just not as much.
As said above engine braking is used to control speed rather than actual bring it to a stop.Ah also I missed off, there’s a lot less engine braking on modern petrol engines as they have heterogenous charge (lean burn/direct injection) and often throttle-less running to boost fuel economy under idle/light loads, plus engine downsizing.
Often valve opening is used to some degree to mimic the throttle, and on some applications engine braking is optimised (HGVs) by setting valve lifts to restrict the flow of air through the engine and not injecting fuel, but I’m not aware of any light vehicles having engine braking built in. It’s a design case for a lot of engine components as nothing gets nice, cool fuel sprayed all over it, potentially for the duration of an alpine descent.
endoverendFull MemberThis could be even trickier if you have an LSD, and will make things very tricky on a RWD car
Is this why you often see BMW’s gracefully pirouetting down the road in fairly benign conditions?…though I’ve always expected it’s the big lump of torque from a turbo motor to be the big culprit.
I’m confused….I would of expected an LSD to hunt for more grip in slippy conditions, is this not the case? Related to this…can someone tell me what something like a Nissan GTR with front and rear diffs and torque vectoring is like in the snow? is it amazing or awful? Obv’s I need to know just in case…
philjuniorFree MemberI’m confused….I would of expected an LSD to hunt for more grip in slippy conditions, is this not the case?
More grip for traction, yes, but both wheels spinning at once which could reduce lateral grip once you’re getting wheelspin (as 2 wheels are spinning instead of one). Also, rear wheel drive means you oversteer rather than understeer in that situation.
All an LSD does is redistribute some torque to the wheel that has more grip at the time. This can be done in various ways, but that’s not really relevant here.
Most traction control systems these days will also mimic an LSD by applying the brakes a little to the wheel that’s spinning. With an open diff, this feeds more torque to the other wheel. Of course with traction control, the amount of slip that one wheel will experience is limited, but that doesn’t make it totally fool proof. Same goes for ESP (and automatic steering into the skid, which I can’t remember what they call) which will try to bring stuff back into line, but doesn’t make the car uncrashable if for example you over-correct or just react with blind panic.
EdukatorFree MemberWithout an LSD you get exactly the same traction from both driven wheels and it’s equal to the traction from the wheel with least grip. With an LSD you get the most traction from the wheel with most grip and some from the other one too. So when there’s a difference in the grip between the two wheels it makes a lot of difference. It also means the car pulls under power as one wheel is pulling more than the other, so much so that in the days before power steering, FWD cars with LSDs required a firm hand to keep them in a straight line under power.
stevextcFree MemberProbably because it makes it more difficult for people who can’t drive very well to accidentally rev the tits off it.
Probs the same people who brake on bends all year round…?
Yes, if you shift down and just dump the clutch – the trick is shifting down and feeding the clutch in slowly, so there’s no jolt that could unsettle the car; keeping everything smooth is golden.
The trick is really just to control your speed well in advance… whereas that’s ALWAYS a good idea sudden ice its even more a good idea. Regardless emergency braking is going to be on the brakes anyway… by complete co-incidence I was driving through an icy new forest yesterday night when a pony emerged round a blind bend… I was going uphill at the time ….so not strictly relevant other than I was going an appropriate speed for the ABS to do its job… though perhaps because I’d need down the last hill using engine braking.
In other words all seems like a non-argument…. keep your speed down using the engine … emergency brake with brakes.
The topic ‘Engine Braking?’ is closed to new replies.
